6
67Boomer
I have a couple of annoying gremlins on my 1992 convertible and was wondering if someone can steer me in the right direction to resolve the problem(s).
1. Passenger side power window will not operate from the driver side control at all, but it will work with the switch on the passenger door after giggling the switch. My first thought was the window switches were bad, but both at the same time? Could there be a loose connection at the window motor? Any suggestions on where to begin troubleshooting?
2. Water Temp and Oil Temp gauges do not work. HOWEVER, the digital water temp and oil temp on the display seem to operate fine. Thought about sending units, but seems odd that both water and oil are bad. Are there separate sensors (sending units) for the guage vs. digital display? I checked all the fuses and they appear in order. Any help on this one would be appreciated as well.
Thanks in advance.
Phil
Thanks in advance.
Phil
