Eddie 70
- Joined
- Oct 28, 2002
- Messages
- 383
- Location
- Kingston, Tn
- Corvette
- 1970 Convertible LS6 and an 02 EB Z06
Welll I finally have a set of Astro Vent doors that I think is working correctly. I guess the previous owner must have disconnected everything and hoped it would make the car run better.
This is what I know about how MY Astro Vent works. Let me know if this is correct.
With the car running,
1. All the heat and vent controls off the doors are opened.
2. Vent controls closed the doors are opened.
3. With the rotary hear, de-ice, de-fog switch in any position the doors are opened.
4. When you select any temp/heat setting the door goes closed.
I hope this is correct because none of it has worked correctly since I have had the car. Let me know if any of you guys works the same way or if it is not working correctly.
_______
_______
