Bill75
- Joined
- Jan 1, 2004
- Messages
- 698
- Location
- Somers CT
- Corvette
- 75 Coupe ZZ4, Brodix IK-180's, Headers,TK0-500
I've replaced every gasket, vent door gasket, and hood gasket that I could find and put a shutoff on the hot water feed to the heater core. Yesterday we drove to the shore and the heat was pouring from the heater all day. It's only happening when the car is in motion so there must be a vent door open or leaking somewhere. I've double checked the heater controls on the console and they appear to mbe to be working according to the vacuume schematic in the book.
Today I was poking around and found what looks like a vacuum actuater up high under the right front fender. It's just behind the screen in the fresh air inlet. I worked the heater/air conditioning controls to all possible positions and didn't see the actuator move at all. I removed the vacuum line to it with the engine running and found vacuum present on the line, and no movement of the actuator when I did so. When I changed the heater/air conditioning controls the vacuum on the line changed which would indicate the controls are functioning properly.
It kind of looks like this actuator might be the culpret but it's hard to see what it's supposed to be doing.
Attached is a schematic of the heater controls. Is this what could be causing the air flow in the heater and getting into the cab??
Bill
Bill
