My car did not come from the factory with the UJ6 LTPWS option, at least according to the options list on the car. I'm the fifth owner of the car
I had the Vette at Willow Springs Raceway this weekend, and wound up having a wild ride off-track. Nothing seriously damaged, but I picked up a small rock between the rim and bead of the left rear tire. When the tire shop dismounted the tire from the rim to clear the rocks out, there was a white plastic box mounted to the inside of the rim with the biggest hose clamp I'd ever seen! I was in a hurry to get the tire mounted back up, so I didn't take the time to really check the thing out.
What could it possibly be? Is it possible that GM mounted plastic boxes on every rim, but only put the sensors inside the ones going on cars with LTPWS? Or maybe some sort of aftermarket system?
The only other thing I can think is that the wheel was aquired aftermarket, although it is the correct wheel for my Collector Edition.
Sorry for the long post, and your opinions are very much appreciated.
