jmccloud
Looking at a nice red '96 auto. One of the front anti-lock sensors had a broken lead (rubbed against the wheel) and had lit up the 'Anti-lock' light on the dash. Repaired the broken wire (solder + tape, not a replacement). Read good continuity with and ohmeter thru the sensor. Disconnected the battery for about 2 minutes to try and remove any codes. Checked fuses.
The 'ABS' light remains lit on the dash and a hard stop on slick grass reveals that the ABS is not functioning.
Does the OBD II store a code for this? Does it maintain the code and defeat the ABS even after the battery has been disconnected? How to reset the condition?
