Any Advice? Removing Diff. Gear Box
95ZR1#418
Missoula, Montana USA
95ZR1#418, 88Z51Coupe, 69L46Coupe
I'm going to remove the gear box on the '95 ZR-1 and have gears installed. I will simply follow the service manual. Any tips etc would be appreciated. So far I plan to use a jack to decompress the rear trans. spring, loosen air duct, remove wire plug from wiper motor.
How about reassembly, do you treat the bolts(clean & oil them)before torquing, whats the best RTV to use on the carrier?
