Any TPI Experts out there?
terrykrueger
MKE
1987 Not a Sh*tbox anymore
OK so my 87 L-98 ran the same since I've had it - a bit of a rough idle, but otherwise flawless. Did plugs, cap wires, rotor, PCV, and fuel filter. Still a bit of a rough idle. Went to clean my fuel injectors (canister) and mimicked the fuel pressure on the vehicle (it was in the normal range although I don't remember exactly where - low 40's?)
Anyhow whn cleaning I thought - "I wonder what would happen if I gave it a few more PSI" then it ran so smooth it was like a hybrid at a stop light. After that - back to normal. Any thoughts?
vetteboy86
IN
1986 Black "Indy 500 Pace car replica"
So it ran smooth for a while, and then without changing the fuel pressure it started running rough again? What kind of adjustable fuel pressure regulator do you have, and how did you set it? Also might want to check the condition of the vacuum lines in that area, to the regulator.
terrykrueger
MKE
Actually I was using a canister to clean the fuel injectors. You set the air pressure at whatever your fuel pressure is and then it emulates the fuel pump/regulator. So when you turn the air pressure up a couple of pounds its 'like' haveing an adjustable regulator (until you take off the canister and drive away)
