sounds like a good deal. do they have sonic map and bob sheet for the balancing?? who's internal parts, is it Eagle, Scat, Etc?? SRP pistons are top of the line. just need to see what your goals are to fit parts for your application. i like 6.0 rods, most shops run 5.7 stock 350 rods on a 3.75 stroke crank for their 383's. the 6.0's give longer dwell time at both TDC and BDC. also the piston speed is increased mid stroke and the latteral "push" into the cylinder wall is reduced, all adding up to better volumetric eff. 5.7's work, 6.0's work better at an added cost. just check the deck height and see where the pistons are at TDC. things to be aware of are piston to valve clearence, valve relief/dish for compression ratio, quench height, cam selection and main bering clearences. let me know your power goals and we can start getting you a parts list together. Brian
