Question: Anyone know the size of the bolts?!?
Bolisk
Crystal Lake IL
1972 LS5 Convertible PS, PB, A/C
I noticed recently that my project car did not have the front lower plastic air foil (whatever it's called). So I bought one. When I went to install it. . .I noticed that the two large center bolts that mount the lower bumperets and air foil to the core support. . .are missing.
Anyone know what the correct size, threads, and length of that bolt is? I don't want to order a whole bolt kit when I can just go to the hardware store.
If anyone knows . . . I would greatly appreciate it.
Thanks,
Jon
Do you plan on having this judged???(NCRS)
If not just find some that fit and use them...
Other wise you could look in the assembly manual and find the sizes in there.
Sent from my DROID RAZR using Tapatalk 2
No not planning on getting it judged. Problem is that I don't know the size and I don't have any that fit. My assembly manual does not tell me the size.
I won't be home till the weekend to check on mine.
Take a tape measure and measure the holes..if you don't want to wait till then;)
The AIM shows the part number, not the size. The Parts and Illustrations Catalogue lists the size as 7/16" x14 x1 1/4" This particular size is very common throughout the front bumper hardware set up and is used in several different places. Doesn't hurt to keep a few spares around the shop.
:thumb
