Working on console plate now. The ashtray lid doesn't stay up all the way. In taking it apart I found only 1 lid slide, is there supposed to be 2? Is that even the problem? thanks, Jim
That was the problem with mine, I though even with the new slides it would come open so I just put a little piece of plastic in the bottom and slid it shut. Since I don't use it I don't have to worry about opening and closing it. It stays shut now.
You can also "bend" the door ever so slightly so that it looks normal but holds itslef into place....very very slight bend...nothing huge....bend from front to back...
