Turtle said:
Oh - I should probably clarify - I was hoping to find something that would fit
inside the rougly 12"L x 9" W x 4" D rear glove box next to the battery. I saw a photo once and just wanted to see if anyone was actully making and selling custom enclosures or something
Hi
I use to be in the car audio industry but i've been out of it for a number of years now so I'm not current on what all the latest offerings are from the various sub manufacturers. The size in that compartment is fairly small but not unreasonable to work with - especially considering the small size of the interior of the car. Don't underestimate what amount and quality of low-end bass you can get from even a single 8" subwoofer and many 8" subs are designed to work in very small enclosers like your trying to do.
One of my favorite Subwoofer manufacturers was JL Audio.
WWW.jlaudio.com
do a search on 8" subs and look at the models 8W0 or 8W3v2. Both work well in very small sealed enclosures which is what I would recommend to you.
When I use to deal with JL Audio they were also great with customer service and tech support. You could call them up, tell them the car you had and the space you have to work with and they would bend over backwards to help you select the right sub and also recommend the best type of enclosure to use it in for the best sound possible. No other company came close to that level of service. The company has grown a lot since than but since MANY of the same people are still there (I looked on their website) I would venture a guess that their customer serviceand tech support is probable still excellent. They really do want their speakers to sound good for you.
If it was my car, I would probably consider do this: (unless JL Audio suggests something better of course)
line the inside of the compartment with a layer of fiberglass to strethen the plastic. Fiberflass has great acoustic advantages because it won't resonate. Using 3/4" MDF wood, make a top cover/mounting plate for the enclosure and cut out a hole to drop in the sub to mount it. Also try to fiberglass the top plate in to the rest of the enclosure. Depending on your skill level you could also tilt the angle of the top so the sub is somewhat angled towards the top rear of the car so the sound "loads" against the rear glass instead of just firing straight up. This would help increase the amount of bass produced.
If you have more advanced fiberglass skills, you could even go a step further and make a mold of the compartment and make the enclosure completely from fiberglass outside the car and than just drop it in. This would have the advantage of being removable if needed and not causing any permant changes or damage to the car.
Depending on just how fancy you want to get, you can make it completely stealth so nobody even sees it. It all depends really on your skill level of working with fiberglass and/or wood.
You may want to check out some of the high-end car audio shops in your area and have them make suggestions also. While you are there look at some of their work they have done either in actual cars or in pics they have of their work. Every high-end audio shop I knew had photos showing their work. A good installer can put a sub in that compartment for you and make it sound good. A better installer can do the same thing but also make it stealth so nobody even knows it's there until you turn the system on. I've always preferred stealth systems myself and besides, the less people know whats in your car the less incentative they have to want to break into it.
Barry
