W
wichitacorvette
Ok, I got my tach up and runnign but its obviously not working right.... at idle it hops around 3-4000 rpm...... give it a little gas and she shoots to max......
yes its set up for the 8cyl (no wires cut) and yes chassis ground and positive from ignition wire....
What is going on????
I do have a tpi motor..... with a msd blaster II coil, but no msd ignition..... using the factory tach wire that usually goes to the factory gauge. should i go to the - on the coil?
HELP!!!!!!!
HELP!!!!!!!
