B&B Tri Flow Exhaust
D
Doutdoor
Does anyone have any experience with this exhaust system. It looks like a well built system and I like the exhaust tips. Any feedback would be appreciated. I'm looking for a good system. I've also looked at Corsa and like what I saw. This is for a 92 LT1.
Thanks,
Dave
-=Jeff=-
Bartlett, IL. (Chicago Suburb)
1990 ZR-1
depends what type of sound you want..
My friend has the B&B on his 94 convertible.. nice deep throaty Sound..
Corsa sounds okay but is too quiet on a stock corvette..
BigRed
Edmonton
1985 Bright Red Rocket
When my Dad was in the Northern Alberta Covette Club quite a few C4 owners used the B&B Ive heard nothing but good things about them if that helps.
D
Doutdoor
Thak You everone for the reply's.
Dave
J
johnny
Dave,
On my 86 vette I use the 2,5" after kat system, it look hot and it sound hot. If you are looking for a silentssystem, buy original mufflers. If you want something hot, buy B&B.
My friend has Corsa 3" under his zr1, this is hot also. Good kwality and performance.
Al the rest sucks, believe me.
BigRed
Edmonton
I sure like my Dynomax SS Mufflers, also the Borla are a excellent choice.
J
johnny
I am so sorry, I forgot de dynomax mufflers! But I do not like the Borla's, I had a Borla's before and they add NO extra power. Not one single hp.
BigRed
Edmonton
Really! Wow for the money they are you'd think they would give you something..huh. I know the look good and are stainless but forget them if they ain't a good performer.
J
johnny
and something else, I had a Borla under my JEEP. It cracked after 100 miles.
I had a new one okay, but it still cracked.
Edmond
Louisiana
2003 Z06
Dave,
I've heard a Tri Flow on a 94 ZR1 and the sound was just earth shattering #@$#
It was very intimidating.
Twin_Turbo
Enschede, The Netherlands
1982 Twin Turbocharged Red/Black
Borla mufflers WILL improve your power & torque simply because about every aftermarket muffler has less backpressure than the stock mufflers. This means that if the power increase is zero you have a restriction elsewhere, most likely in the catalytic converter.
Furthermore, the stock 2-1-2 system isn't very good, the 2.5" pipes are restrictive. You should go for at least a 2,75" system or better yet duals (at least 2,5")
The only marketed muffler with close to 0 backpressure that I know of is the Borla XR-1.
A cat back system (after cat?) is NOWHERE near effective enough for power levels over a 250-300 Hp. The front Y-pipe is one of the most restrictive parts after the headers.
There's no substitute for a good handcrafted 2x 3" stainless system!
Marck
Edmond
Louisiana
2003 Z06
Marck
I had a conversation about HP improvements with respects to the exhaust on a guys Mustang. He bought Flowmasters and said they advertise a 10% increase in HP. I told him that he would only see a 10% increase if he optimized the whole exhaust system from engine to tips. Am I correct?
From what I've read here in the CAC, any after market performance exhaust is better flowing than stock. I do believe that it is BigRed who stated that the C4 exhaust is more restrictive than the C5, thus you would notice more improvement.
Twin_Turbo
Yes, all stock systems are restrictive. I'm not sure what to say about afvertized improvements, usually it's in combination w/ other stuff as a marketing trick..
Also, an increase in percentages is silly, that means the more power you start w/ the more gains but actually when you'r running a lot of power the header size quickly becomes restrictive again.
Marck
J
johnny
Mmmmmmmmmmm..................
Indeed, the stock mufflers are resticted. But when you buy aftermarket products, buy the best.
You buy a B&B or a Corsa. I think Dynomax is also good.
Value for the money.
Borla isn't cheap either.
And, on the Dyno I did not see any improofment, with the B&B it does.
Edmond
Louisiana
2003 Z06
Guys, go easy on me, it was only a Mustang:D LOL.
I personally went with Flowmaster and the system should be coming in next week. I can't wait to install it because I know it's a definite improvement over what I have now, which is basically stock. After I install the catback system, I'm going with a HyperTech chip and then open up that air filter.
Twin_Turbo
Did you dyno the same setup w/ the B&B and then w/ the borla's (or vice versa)??? I find this very strange, a buddy of mine dynoed quite some combinations and has found the borla's to outflow about anything. I'm not talking about the XR-1's here but about the stainless ones!
Marck
D
Doutdoor
Exhaust Systems
From what I've read guys, a system called Power Effects will out flow any system. Their testing reveals a 55% better flow than stock. The Borla system was next at 42%. The Power Effects system is a complete stainless steel 2.5" tunable exhaust system meaning you can adjust the exhaust flow rate by turning valves on each muffler to attain the sound and performance characteristic you want. I thought that was pretty cool.
The tips are black though and still look pretty nice, although I think I prefer the chrome tips on other exhaust systems.
Twin_Turbo
The PE system uses little motors to open and close a valve in the exhaust.... that's a little ricey for my taste.
Are you talking about the cat back system here?
Marck
Tomrw
Columbia, MD
2000 Black Conv. Bassani Exhaust.
I have a Bassani Quad Catback on my C5 and I love the sound and profromance.
