M
Mciamp99
I am back and the LT-4 in the 75 was running fine, then it started to quit. It would run until hot, then the fuel pump would shut down. After a few minutes it will restart but quit soon after. I found no codes, I still have a noid light when I try to restart. I changed the relay and still have the same problem. I only have 38 psi at the fuel rail head and then it drops to zero when the engine dies. I did jump power to the fuel pump and the same thing happened. My fuel pump is in the gas tank. I am using a 96 Fuel Pump in the 75 tank.
It seems to me that I have a bad fuel pump, does anyone agree or have an alternate suggestion.
This forum has been great, thanks for all your help.
