Peer81
Hello everybody,
After checking my timing chain i'm rebuilding the "front" of the engine.
The first problem is that i don't remember how close the harmonic balancer was to the timingcover.. So do you guy's have any idea? Is it realy oke when i just fasten it to manual spec's, it's 60.. something...?
I don't have a setup tool and just fasten it with the center bolt, i also placed a sleeve on the balancer so the original marks of the original seal. The balancer is now about hafway past the ignition timing metal (the egde of it). And i think i'm already to close to the timingcover..
Another way to get an idea of the place is putting the belts back on and see how the roll on the crankpulleys.
The only problem is, the waterpump is not on it, the airpomp is also not in place, for the generator the same... Only the airco and powersteering are in place, but i don't know the sequence of the belts.
So can somebody tell me on which of the three crankpulley's the belts go?
Starting with the
Generator - waterpump - crank.
Airco - waterpump - crank.
Powersteering - crank and airpump - waterpump..
From the engine to the outside.
It's a bone stock L81!
Greetings Peter.
Starting with the
Greetings Peter.
