jim's82
I'm hoping someone may have a suggestion.... my 82 vette has had about everything imaginable thrown at it to fix it's problem & nothing has worked yet. Every cold start, the engine surges so bad that it sometimes dies without help on the throttle. If I go ahead & throw it in gear & drive before the engine is warm it runs terrible below 1500 rpm & hesitates severely from idle. After the engine warms up it idles much smoother but is still sometimes intermiitant. One minute running smooth & the next picks up a little bit of a rough idle then hesitating from idle (not as severe as when cold). It's a 39K mile car with all original parts except for: new computer, TPS, coolant temp sens., EGR,intake man. gasket, plugs & wires, new dist. cap & coil. What am I missing??? My mechanic says that the fuel injectors are working correctly but he's at a loss now & seems as frustrated with the car as I am. I bought the car last winter for my wife for Christmas.... she hasn't driven it yet!! Any suggestions or insight would be GREATLY appreciated.
PS - My mechanic's last idea was to change the fuel pump although we haven't checked the pressure yet.... I may be looking at this wrong but, I figured since the car runs really bad at idle & runs best at higher rpm's, the demand for fuel at the higher r's wouldn't be met if it can't meet what it needs to idle. Does the fuel pump supply a constant PSI or does it fluctuate to demand? Thanks again, Jim
