alson81
Does anybody know how to set the base timing on a 81 vette? Is ther a wire to be grounded out or something opened up.
Thanks Guys i will give it a try. I am also having trouble finding a mechanic that knows how to set the carb. I got it rebuilt when the motor was done. I have been told the Throttle position sensor is to be set with a scan tool? Idle mixture screws are set at 3 1/2 turns, my vacuum is around 14-15 inches. Sometimes it idles at 750 rpm, sometimes 1000, sometimes 1200, it also runs a little rough when cruising at 1500 to 1800 rpm. Not sure what is causing this. Any ideas?
Thanks Al
Thanks again , tried the timing thing today. The car won't run at 6 degrees, runs fine at idle @ 12degrees, not so great going down the road it hesitates alot . If i advance it to around 20 -22 degrees it seems to run good down the road but i know it should be @ 6 to 12 degrees. Could this have anything to do with my temperature sensor in the intake? The ceramic top is broke not sure if it is working or not. I have a new one but the other one is seized in the intake and i don't want to break it off in the intake.
AL
....The check engine light is not on. I don't understand why my timing is @ 22 degrees in order for it to run decent. I am leaning towards a vacuum leak also because i can only get 15" vacuum max. The temperature sensor is the wired one. I don't have a scan tool or have any idea where to connect one if i borrow one. Where can i get a factory service manual?
Thanks Al
