K
		kowalski
So, my 73 is dead. No power at all.   Actually thats not true as it occasionally has the door open buzzer and interior lights come on.  But as soon as I try to turn the ignition, or turn on the fog lights, it goes completely dead again.
Figured this might be the ground from the negative battery cable. Located ground underneath car and played with cable a bit and it seems to be atleast part of the problem.
I've heard that Vette's need heavier duty battery cables and that I shouldnt buy cheap ones? Any tricks to swapping out this cable?
Does this have to do with why I cannot turn ther ignition back far enough to get the key out of the ignition or is this a seperate issue?
ad
