joshwilson3
I just got an AC Delco 60 series group 75 battery for my 89 Vette. I figured it would be a good time to do a battery drain test.
I then connected my multimeter in series with the negative, and then also did the positive as well. And the draw was at .14 milliamps. So, I figured that was good.
I had an Autozone test light I figured I would also use to test. I checked it out across the battery to make sure the bulb lit up. Then I did the drain test, connected one lead to the positive wire, and the other lead to the positive pole on the battery.
Well, the bulb lit up. It wasn't dim at all, but just slighty less than when I had it hooked up to the battery. I then pulled my meter out, and it was still measuring .14 milliamps. I figured at that figure the bulb shouldn't be liting up?
So, I pulled all the fuses in the fuse box. The bulb still lit up and I was still getting the same .14 milliamps drain. So, I then disconnected the alternator with no change.
So, does it sound like something is wrong with the test? I did notice that when I hook the battery up, the inside lights come on. I don't know if that is supposed to happen. But the thing is, when I connect the test light or meter in series to one of the cables, the inside lights don't come on.
