P
purple-vette
I acquired an 88 coupe and first problem is battery goes dead in about 2 days. I checked the battery and charged it fully then put a test light between the negative post and the negative cable. The light stayed lit while a pulled each and every fuse from the fuse panel on the passenger side of the dash. looking to isolate the short. Are there any fuses or circuit breakers other than the panel on the right side of the dash.?
I noticed while reconnecting the ground cable I hear a faint click coming from the drivers side headlight motor. The motor doesn't run or move , it just makes a click? The headlights work properly so I don't think there is a problem with the motor.
Any ideas would be appreciated.
