The battery in my 79 drains dead after about 3 days if left in the garage. I did a current drain check with a multimeter set on 10 amps and got a reading of 1. When I pulled the courtesy fuse the reading goes to zero, however the radio also quits. Radio has its own fuse just above the courtesy fuse. The radio goes off if I pull either of these fuses. Prior owner had a radio equalizer, which has been removed, but many wires still remain. Any suggestions on how to go about fixing this???
JohnnyJ
JohnnyJ
