vett03
I just change the battery in 2003 vette,it will turn over but it will not start.Did I miss something.All lights ,gages work, can't unlock radio?
This is Greek to me Never heard such a thing! Buffalo Chips,Your Smoke'n better stuff than me!!daffycats said:I ran into this as I was growing up tried to swap battery out of monte-carlo to my z28 and would turn over but not start. I was just try to test fire new motor so I got my father involved, "electical tech guy". The battery even though was 12v it has to match patern in electronics. I had to hook up old battery back to car a junp off other battery started right up. It was a learning trial for me. So you may be 1-digits off in your battery selection. Good Luck
If all else fails try to jump old battery off of new one. The old one has to be hooked up to car terminals.
c4c5specialist said:HI there,
Your radio can be unlocked at your local dealership.
As far as what you are missing, there may be other issues.
The battery disconnect should NOT affect your starting of the vehicle.
Allthebest, c4c5
gmjunkie said:This is Greek to me Never heard such a thing! Buffalo Chips,Your Smoke'n better stuff than me!!
There has to be another Problem!! C4C5specialist is a Specialist and Knows What he is Doing!! If Paul said it I believe it!!![]()
Yeah Man Sorry!! I've been in the Cave too long!! I probly offended you more!!! Some say I'm not House Broke, Sorry!!daffycats said:GM sorry I dont smoke anyting
I just trying to explain something that happened to me in the past. And when it was explained to me it made sense at the time and worked for me. For all I know it may be greek. I am only pipe fitter by trade my father had years of electronic school not I. Just trying to help somebody check something, with an alternative. Good luck guy sorry if I affended anyone.
There is a Wealth of Information here! And Ton's of Fine people!!
Thanks for the feed back.I don't know what happen,but after about hour and a half it started right up wite no jump, and was able to unlock radio.It's one I never came across??mrm1149 said:Possible ignition switch?
zagger said:I know local dealers use a small gadget they plug into your cigarette lighter, it maintains small voltage in the system while the battery is being changed. It preserves all seatings for key programing and key fab, PCM memory and other presets. On my Durango I have to race the engine till the thermostat opens and oxygen sensor take hot reading before the thing will idle after battery interrupt. I'll bet the starting problem you encountered had to due with PCM reseting itself.
