Question: BBK intake manifold w/ Throtle body
killerc5
los angeles
hey guys
i am really interested in putting to my 2000 C5 the
[h=1]BBK SSI Performance Intake Manifold 5004[/h] with the 80mm throttle body:W but i was wondering if any of you guys have put this intake and what are the results your car respond good. Because i wanted to put the z06 intake but i was reading that this one give more HP then the z06 one and its a lot cheaper then the z06 to what do you guys recommend.;)
thanks
Please, describe the modifications already done to the engine.
ok it has ram intake LT long tube headers with HI flow cats, BBK under drive pulley, corsa exhaust. but i want to put the intake manifold before i take it to the Dyno.
:cool
thanks
A few years ago I installed the BBK intake manifold & 80mm TB on my '99 C5 convertible. I also installed shorty headers (I know, go ahead... they are useless). The car already had a Corsa cat-back exhaust w/ X pipe when I purchased it.
My buddy and I tuned the car with HP Tuners software and there was a significant difference in the "feel" of the car when driving and power. I never dyno'ed the car, but it is definitely a lot more fun to drive. The "butt" dyno says it is worth the money to do.
CG
I suspect you'll spend a lot of money on that intake manifold and TB combination and it will not gain you much performance.
If you had an aftermarket camshaft and/or different heads, then that manifold/TB pairing might really be worth the money.
thanks guys for your replies
i have been doing some homework on this subject, and alot of the members here have the ls6 intake and they have gotten good results,:) and they have also talk about the heat sink:ugh on the BBK and some other stuff.:argue. and yes im going to be installing cams as well but thats after the intake, need to save the money:D
