Belt Pulleys
  • Thread starter Thread starter matchframe
M
matchframe
I am still in the planning stages of how to build the engine on my '78. I am going to build the engine myself and have just located a good performance machine shop near where I live. My goal is to get about 400 to 450 HP. I am starting with a new 4 bolt main block with a new steel crank, and building from there. Is there much performace advantage in going with a serpentine setup like what March offers? Or is my money better spent elsewhere? What would you recommend? Thanks!
Bill
Bill,
I have the March system on my car. It looks nice, and provides great accesory control even at high revs. It was mondo expensive though, and if I had a choice, that money could have made more hp somewhere else.
Any performance gain will be minimal.
However....if you honestly plan on cranking that much hp from a small block you will be doing it at the sacrafice of driveability at certain low RPM ranges, emissions, and noise. You will need to shave off every corner possible to reach that peak goal on a consistent basis.
I know I am sounding like a broken record, but you really should explore the possibilities of a big block. There are plenty of them out there from boats, trucks, motor homes, waiting for a new body to live in. It requires NO mods to your car--other than maybe hood---but you want a cool hood anyway. You will even use your same motor mounts! Plus hooker side pipes would be wicked cool on your car.
You can get the 400 hp range out of a 454 with little overall effort, no sacrafice in driveability, and you get the freaky wild stares, glares, and drooool every time you pop the hood. It is hard to get a small block to turn any heads unless you are beating the snot out of it on the strip.
Just my .02
Chris,
Thanks for the input! I have been going back and forth between the idea of a Big Block verses Small Block. I use to own a '68 Camaro that I put a 427 in. Those were FUN days! You may have put back on the right track. I was planning on buying an L-88 hood before I went back on the street anyway so the clearance should be no problem. I can't wait to drive my Shark again!
Bill
Think about a sleeper 383- BB power in a SB.
:cool
