malc350
Has anyone found their tensioner doesn't move under tension?
When I put a wrench on the tensioner bolt (with a long bar for easy leverage) my tensioner doesn't appear to want to move, although I can see it flexing a bit while the engine is running.
Because I felt I might put too much pressure on the bolt I removed my belt the hard way - by loosening off the alternator and carefully removing the pulley on the AIR pump.
Has anyone else had to do this? I get a bit paranoid around the "Callaway only" parts in case I break something and I can't use my car (especially as the sun's out all the time now!)
I've removed the belt on my 84 and 93 and though it's always a bit tricky, they didn't seem to need the amount of leverage I felt I needed to put on my Callaway. I don't suppose the tensioner can seize?
