T
tscott9330
Are offset trailing arms worth the investment? Do they allow big enough tires to make a big difference in traction?
How big a rim can you run without offset trailing arms, and how big do the offsets allow you to run?
Also how wide of i tire can i run With and without? If you could give tire width in inches becuase I dont quite understand the tire size codes.
Thanks, Tom
Thanks, Tom
