norwegianvette
Anyone out there who can give me a advice on which to chose:bash
All the best,
Steve
All the best,
Steve
All the best,
Steve
All the best,
Steve
Well, Steve....first, you need to tell us what kind of driving you do with the car.
As for comments elsewhere about the 86 Z51, part of why a car like that rides hard is the springs. Z51s are stiff because of the combination of shocks, springs and stabilizer bars, not just the shocks.
As for the car's steering being touchy, shocks have nothing to do with thatr. What makes the pre-89 Z51s "touchy" is the quick steering rack on those cars.
My driving is mostly cross country and i never used the car on track. With this i guess a shock from others than bilstein will do me best? I have bilstein on at the moment and they are close to 50K miles so i want to replace them.
Steve
I have 87K on my bilsteins and have no leaks. I think I read somewhere Bilstein suggested replacement at 100k or beyond.
Are they leaking? Does the car handle strange on the highway?
Also, a stiff shock will make a car twitchy in a way. If the shock is too stiff, the initial transfer or load on the spring at the beginning of the turn is less. Basically, the car dives less at the beginning of the turn.
So a car equipped with stiffer shocks feels like it turns in faster because the initial energy is not absorbed by the suspension. The stiff shock prevents this initial loading of the spring. So the energy is spent turning the car and not compressing the spring. It’s only for a split second at the beginning of the turn but you can feel it. It’s a strange relationship between shocks and springs.
If you can find a copy of How to Make your car Handle by Fred Puhn, you can read all about it and the differences a shock can make. I found out the expensive way racing in amateur SCCA events.
Check out KYB's as a reasonable ( less expensive) alternative.
