I agree with Ken.
John,
My 81 Coupe does the same thing. It was worse the other day before I had the 795 CFM Edelbrock carb tuned.
I am thinking of doing a compression test, both wet and dry, to see if the seals are cactus. I suspect they are as there is a little oil being used between changes.
Either way, the compression test will show where the problem lies.
I might add that we had the heads off a little while ago and the head gaskets were genuine GM, used in production. I suspect and my mechanic agrees, that they have never been off in 22 years. We found a little carbon, from the seals letting oil through, I think.
Cheers
Tony
