Blue, Bronze, Smoked T-tops w/ White 81??
91-Vetteman
Richmond, VA
1991 Blue Coupe
Looking at possibly replacing my t-tops. My Vette is a white exterior with red interior. Was there a set color / type of T-top that came with a particular color this year of Vette ?? I have seen various tints advertised, blue, bronze and smoked. I would appreciate all you white 81 Vette owners to respond !! Thanx !!
there are also mirrored ones, and then ones that are solid and the same color as your car...
not sure though
The pair I have doesnt appear to have a blue tint. Always thought they were mirrored. I assume the blue safety flo-lite in the code means they are supposed to have a blue hue? /shrug
I dealt with this question a few years back when I had to replace mine. There were several different tints (depending on code on glass) it appears. It seems most were blue (looking outside when in the car) and mirrored on top (when looking back in), however some fade to bronze, and I believe the '82 corvettes all came with the bronze tinted. However, if you get an aftermarket set, all will be mirrored outside, bronze inside, at least that is how it was when I was searching. I wanted blue because I have a blue interior, but the aftermarket only makes bronze. My suggestion is to look on ebay for a good used set in the color you want (big bucks!) or go to one of the aftermarket places. I found mine for about $800, and sent my originals to them. Oh, and smoked class just looks like tinted glass (to me at least), and were not stock. Hope this helps, and someone please chime in and set me straight if I'm wrong.
-Tatortot
the blue were from the st. louis vettes
the smoked mirrored were from thr bowling green plantas were the the bronze which were for the 82 collector's edition...
hope this helps
T-top Glass Tints
Thanx Bill !! I currently have the M92A which are a darker (almost black) smoked t-tops on the car right now. I am the 3rd owner, not sure if original or not, they look like the original. According to my build sheet #, my car was built in St Louis, which would be the blue tint, M1131. We will see if anyone else checks in. Thanx again !!
Mine are mirrored with the blue tint inside. My car comes also from St. Louis. Also very expensive to replace.
Rawj said:
Thanx Bill !! I currently have the M92A which are a darker (almost black) smoked t-tops on the car right now. I am the 3rd owner, not sure if original or not, they look like the original. According to my build sheet #, my car was built in St Louis, which would be the blue tint, M1131. We will see if anyone else checks in. Thanx again !!.
Those are the ones I have for sale John. Working on the pictures for you.
So let me get this straight, They came with to sets of tops? The hard top and the mirrored ones?
mine too HAD the blue,I have them in the shed up in the rafters as they are both cracked:cry ,I bought another set (smoked grey) mirror at carlisle 2 years ago,Iwould like to get another set of the blue ones b/4 they are all gone!!:ugh
No, just one set. My car had glass ones in it when I bought it, but I bought fiberglass ones on ebay - I like them much better, the solids look better and are somewhat cooler, and you know how C3's make heat! Do you have glass or fiberglass now? Make sure which you will be comfortable with if you're going to lay out that kind of money. Just my opinion.
Craig
I know my tops when they are on,it is like driving an oven with the glass( yes I have a heat barrier under the carpets I put in last year after she was painted and b/4 the carpets wernt in),so I purchased the black-out film that goes on the inside of the glass...what a difference :eek it made in the temp of the inside of the vette when the sun was out!!!!
Bill,
Which ones did you get? I was very interested in them, but was worried that some would reduce head clearence. I'm 6'2 so thats not a possibility.
-Tatortot
22229stingray81 said:
Bill,
-Tatortot
I think Bill is referring to the stick-on film that goes on the underside of the glass. It doesn't affect your headroom at all.
Gwen G. red on red '81
Yup!! thats what I got...Purchased it thru corvette central,it is a cling-on type of film-very thin 1-64th of an inch thick...MAYBE,
Thanks for the reply Bill and Gwen. I was hesitant to buy them because it didn't seem like it would be that helpful, but it really is huh? Maybe I'll pick up a set.
-Tatortot
I have the hard top ones (two pieces) and the blue tinted ones. Which ones came with the car? The hard top ones right? Dont want to sell something original. Code on the glass ones is the mll3l
It depends on what was ordered with your car. The hard tops (solid body color) were standard, and the glass tops were an option. Someone will chime in with more information I'm sure.
-Tatortot
All it says on my window sticker is Removable Roof panels. I know there is something to do with codes on the glass ones. If somone knows please do tell
From www.L81vetteregistry.com : RPO CC1 are "Romovable glass roof panels" which were installed on 29,095 '81's, and retailed for $414.00.
RPO #DescriptionQty.Retail $1YY87 Base Corvette Sport Coupe 40,606 16,258.52 AU3 Power Door Locks 36,322 145.00 A42Power Driver Seat 29,200 183.00 CC1Removable Glass Roof panels 29,095 414.00 C49Rear Window Defogger 36,893 119.00 DG7 Electric Sport Mirrors 13,567 117.00 D84 Two-tone paint 5,352 399.00 FE7 Gymkhana Suspension 7,803 57.00 F51 Heavy Duty Shock Absorbers 1,128 37.00 G92 Performance Axle Ratio 2,400 20.00 K31 Cruise Control 32,522 155.00 MM4 4-Speed Manual Transmission 5,757 0 N90 Aluminum Wheels 36,485 428.00 QGR White Letter SBR tires P225/70R15 21,939 72.00 QXH White Letter SBR tires P255/60R15 18,004 491.92 UL5 Radio delete 315 -118.00 UM4 AM-FM radio, etr stereo w/8 track 8,262 386.00 UM5 AM-FM radio, etr stereo w/8 track/CB 792 712.00 UM6 AM-FM radio, etr stereo w/ cassette 22,892 423.00 UN5 AM-FM radio, etr stereo w/ cassette/CB 2,349 750.00 U58 AM-FM radio - stereo 5,145 95.00 U75 Power Antenna 32,903 55.00 V54 Roof Panel Carrier 3,303 135.00 YF5 California Emissions Certification 4,951 46.00 ZN1 Trailer package 916 110.00
I have two sets of covers, a velcro set and a button set. The button set came with the orig tops right?
