firstgear
- Joined
- Oct 11, 2003
- Messages
- 1,895
- Location
- Norwalk, Ohio
- Corvette
- 15 Z06, 01 Vert, 63 SWC & 60 ALL RED
Jim and Craig got over to the house about 10 this morning....I had been up since 6:15....once I woke, I couldn't go back to sleep...so got up and finished a few more things on the car like getting some of the body bolts off....and when they showed up, Craig finished getting the emergency brake cable disconnected and Jim helped me with the last couple of body bolts.
With the car up on the wheel dollys it sure was easy to get underneath to disconnect the last few things.
Because Larry had problems withthe height of his 4 post lift getting his body off, we took no chances and removed the 4 wheels and lowered the wheel drums down on the wheel dollys and pushed the car over to the big 4 post lift.
We got the body in position and attached the straps to the seat belt mounts and to the convertible top mounts just behind the seat location.
We started to lift with just these 4 points, but decided that we needed to attach a strap across the front as well so we put one of my tow straps underneath and attached it to the two overhead car ramps.
we were a little worried that the front end wouldn't take the lifting stress, so I used the ratchet to tighten up the strap and came to the conclusion no problem we would just watch it carefully.
So up we went with the hydraulic lift.....ever so carefully.....
Up she went.....
and then we decided a little higher to clear everything...
out came the frame on the wheel dollys and in went the body dolly
the conquering heroes....
The body safely on the dolly....just a note for others....the front part of the dolly is not required at all for a C1....no where did the body sit on the front part of the frame, only the main portion.....for a C2 it is probably necessary..but not the C1....live and learn.....
The body sitting on the dolly while the frame goes into the work side of the garage for getting ready for the Myers front and rear end that is going on the existing frame.....
Again, specials thanks to Jim and Craig that braved the cold weather and the snow that we had here (they didn't run into snow until the got about 10-15 miles away). Craig drove his RED C5 (it felt comfortable with the other RED cars at the house!) with plates BOSSVETTE.
More pictures and information to follow as more progress is made....and by the way...this is all Barry's fault...if he hadn't started with the carb, and aluminum intake and valve cover cleaning exercise I would not have been motivated to do this....thanks Barry!!!
Up she went.....
