72VETTE454
Hello all! First posting. I have seen a couple of threads similar to this, but not quite. I need to replace the rear body mount brackets on my 72, they are basically gone. Thanks Michigan
ad. They are riveted to the body, so I either need to grind off the heads or drill them out. I know replacing the body mounts is not fun, but possible. I'm just not sure about getting to those brackets with the body on. I plan on jacking up the body as far as possible to gain access. I will be replacing all of the body mounts while I'm there and probably the front mount brackets as well. I haven't looked at the two inner mounts yet. Thanks in advance for the help
