Ed's 1970
Hi all,
The body is almost ready to remove from the chassis. My chassis has some rust and I decided to redo it. I am going to be installing a 540 big block, so all has to be right. Everything has gone great so far. I was successful on 7 of 8 chassis mount bolts. The only one which has given me a problem is the very back one on the driver side, at least it looked easy. I used about a 3 foot cheater bar and it broke loose. Unfortunately, I broke the factory bolt which is somehow spot welded inside of another steel part and the bolt just keeps spinning. U can get access from inside the car in the very back, barely enough room to do anything. My plan is to just grind the head of the bolt off so I can get the shell off and deal with it later. I can not believe the factory installed something like this so flimsy instead of using just a regular nut and washer.
Has this happened to anyone else and any ideas what to do?
Ed
Ed
