bought new spark plugs today!
Edmond
Louisiana
2003 Z06
Got a set today down at the local Pep Boys for $5.99 each. They're the Bosch Platinum +4's. I've read positive things about these plugs and figured that I would try them out and find out for myself.
Unfortunately, I won't be able to install them until Wednesday so I'm in the process of looking for a set of wires as well. Does anyone have any suggestions on a nice set of spark plug wires?
Thanks,
Edmond
R
robert kirk
i went with msd wires on my 92. changed opti, water pump, plugs, egr valve, all the filters, etc, so i can't tell you if they alone helped. msd claims that there wires have less resistance than anyother brand. don't know if this is true or not. they do work just fine, great fit, red so they ad a touch of color. the only problem was they didn't fit the factory wire looms this didn't bother me as the looms were brittle and needed replacing anyway. robert
Ken
Gone but not forgotten
Hermosa Beach, CA
1987 Z51 Silver Coupe
If you spend some time researching who's behind most of the wires on the market today, you'd be amazed that one manufacturer is responsible for most of them, and that manufacturer is Taylor/Vertex aka Taylor Cable Products, Inc.
_ken
R
resto75
Moroso Blue Max on both of mine but I don't know if their the best or not. I don't have any problems but the way I drive it I don't think it would matter much.
E
ErnieN85
I've had Stock (went south), MSD (looked like a minature thunder storm in there) Sent them back! , Mid americas Two sets the last ones just got too old and started leaking (arcing all over & missing), I just installeed a set of Accel 8.8mm universal fit. So you have to be able to cut and install ends yourself. These are working fine.
So original 42,000 miles
MAD 2 sets last one went 60,000 first one went 50,000
MSD 50 miles?
Accel Anybodys guess but only $29 at pep boys
Edmond
Louisiana
2003 Z06
Gentlemen,
With new spark plugs, I should expect a better/cleaner spark and therefore less emissions and better fuel efficiency right?
Is it assumed that when you change the plugs, you also change the wires? I'm assuming that because you're doing the work in that area anyways.
Ken
Hermosa Beach, CA
Wires will age as does anything else, and their functionality will diminish in regards to voltage transfer. You will also encounter the boots/terminals pulling apart, the insulation (rubber) will deteriorate, they get burned by exhaust manifolds, etc.
You should change your wires every fifty thousand miles or thereabouts.
_ken
BigRed
Edmonton
1985 Bright Red Rocket
I run MSD 8.5's but I hear good things about Taylor and Moroso.
Edmond
Louisiana
2003 Z06
Found these on eBay...
Please give me some feedback about them. They sold for $21.00 plus $7.00 for shipping so if I bought them, it would come out to less than $30.00. I have copied the description for the scrutiny of the Corvette junkies here:
Item Description- This auction is for one brand new set of Borg Warner spark plug wires. Borg Warner is one of the top brands and is officially licensed by Nascar. This wire set has a the stock core and is silicone jacketed to resist oil. The distibutor boots are engineered to seal out moisture. The wires are 7mm and are custom fitted to match original equipment. Part number is CH869SP. Picture is not of exact part number. Please view my other auctions for Rapid Fire Spark Plugs for this car!
Application- This set of wires will custom fit- Chevrolet Corvettes 1984-1991.
D
Drewser
Bigger is better
7mm isn't as good as 8mm. I've changed enough wires to know but not enough to have a favorite brand. Besides, most of the wires are made by one manufacturer anyway. Bigger is better.
--Drew:w
V
vetsvette
Good choice on the plugs. I'm running the same with a set of Taylor pro wires. Good fit and they fit in your stock wire looms. They should not cost more than $45 or $50.:upthumbs
C
c4ever
Bullwinkle,
I'd go with a better quality wire than the Borg on E-Bay. I'm running the Accell 8.5mm, replaced all looms for correct fit and they look great. Bigger IS better in this case. Taylor,MSD are all quality wires.
69MyWay
Auburndale, Florida
1969 Killer Shark
go with the taylor spiral pros. They come in sizes up to 10.4 mm. I just put the 10.4 on the 69. I have been running the 8 mm on nearly everything else. You can get them from Summit. They are rugged and come in bright colors. The 10.4 looks like wires on steroids! You don't need anything that large, but it will look cool.
Taylors are pretty easy to make up if you get the custom cut kind.
Wires do break down and will make a car run bad over time. The 7mm would be the factory OEM replacement style. Nothing wrong with that, but nothing special about it either.
jeepie
Dunmore, Pa.
1991 Coupe Blk/Blk
I just changed mine over the winter. I got the following wires:
TAY-74209 Taylor 8mm Spiro-Pro Wires for 1985-1991 L98 Corvette (red)(Plus NGK Spark Plugs)
These wires were already made up, just plug them in. They fit perfect and came with the different
angle wire for cyl 6 to go around the oil dip stick. The set also came with 8 NGK plugs. I paid something like $58.00 to my door for everything.
Two notes, first the wires are a pain in the butt to get routed the same way they were in there. Second most of the wire looms will break when you screw with them, I got all new ones, makes for a better job.
I got the wires and plugs from the following, I am not sure if they still have the plug deal.
http://www.SpeedDemonMotorsports.Com
Good luck.
maxrevs85
Eaton Rapids, Mich
!985 ,blue coupe, 4+3 Z51
Yes Ken, Taylor Vertex.....excellent wires.....widely used in racing. I use them myself. very nice . :cool
Stingray74CC
San Diego, CA
Black Cherry 1969 Stingray
10.4mm
Chris,
I didn't doubt you on those wires looking like they are on Steriods, but WHOA!!!:eek Massive!
(Picture in the L88 Air Cleaner Thread)
Anthony
I
intruder9
Try this link, if it will open. www.magnecor.com
Has good info concerning wires. I've got a set on order, but haven't received them yet.
Will report back after installation. (Have a set of Denso Iridium plugs ready to install also!)
69MyWay
Auburndale, Florida
1969 Killer Shark
Re: 10.4mm
Stingray74CC said:
Chris,
Anthony
A good friend of mine lives and I am sure will eventually die by his favorite phrase "If some is good, more is better!"
D
Drewser
Thank God for small favors
Luckilly there are a LOT of people out there like that. Luckilly for me as I make my money off of other peoples misery (some of the time) and stupidity (most of the time).
Edmond
Louisiana
2003 Z06
I have a choice now...
So I called up two auto parts stores and got prices for a set of plug wires:
$34.99 for a set of 8 mm Borg Warner's
$39.99 for a set of 8 mm AC Delco's
I have the Bosch +4's sitting on the garage shelf and I'm pondering which wires to use.
Any suggestions?
Thanks,
Edmond
