do you want them for looks, or actual 'performance' of the hose?Jman said:Thinking of replacing the upper and lower radiator hoses with stainless steel braided ones. Good idea? Bad idea? Where do I get them?
Real SS hoses would have to have AN aircraft fittings on each end like those illustrated in Ken`s post. An extremely difficult situation to overcome at the radiator and waterpump. Not impossible with aluminum parts, but the fittings in those large sizes are very costly and so is the hose and it does not comform very well in tight situations. This trick stuff was ment for race cars with open areas and not for tight Corvette engine bays. But it`s your car, and you can attempt anything you want to with it and good luck in the fix.Jman said:I want the finished hose and all. Not interested in recovering them just for looks but I'm thinking it is time to do a complete cooling service. Drain, flush, fill, and new hoses. So why not consider the braided ones?
A thought that I've been toying with, an idea taken from old hot rod flathead engines as well as some customs, is to utilize a piece of stainless pipe for the main length of upper radiator hose, leaving short pieces of rubber hose on each end to connect to the radiator and manifold. It might look good. :coolJman said:... jazzing this thing up
It looks great, as I have done it before and polished the SS tube to finish it off.Ken said:A thought that I've been toying with, an idea taken from old hot rod flathead engines as well as some customs, is to utilize a piece of stainless pipe for the main length of upper radiator hose, leaving short pieces of rubber hose on each end to connect to the radiator and manifold. It might look good. :cool
