brake bleeding
joe1975
Louisiana
1975 Orange L-82 4 Sp.
About to finish my front end rebuild I had to break one line on my brake caliper do I need to bleed entire system or just the front
These should be two separate systems. If the rear brakes are effected however, it's time to replace the master cylinder.
just bleed the front brakes, it is a separate system. mike
You just have to bleed the fronts. But if I where you I would bleed the back brakes also. I you haven't flushed your brake system in at lest 2 years do them all. Brake fluid absorbs moisture over time and the wet boiling point decress and with moisture in the line could make the peadle spongy. If you do a web surch on brake fluid you can read in better detail. Beside it wont take long to do the rears.
