G
gearshift
I replaced my passenger side front brake calipar, because it was stuck on close and grinded the brake pads down to the medal. I replaced the brake calipar with brand new pads (the other pads on the car are 1.5 years old). But, when am driving, I get the heavy brake pad smell coming from the side that was replaced, and the rotor and surrounding area is three times as hot as all the other rotors.
I ended up also replacing the master cylindar and power brake booster. Also, the wheel with the new calipar and pads does not spin as freely as the drivers side. There is no leaking, but I believe the calipar is not opening up all the way again.
Anyone with similar experience or advise would be most welcome.
