R
rude dog
my '93 has an off and on again brake fluid leak from somewhere around the master cylinder ever since i had the front rotors off for resurfacing. i did the r and r myself and i know i pressed the brake pads further back in the calipers than necessary. i have the bled the entire system (until clean fluid came out of all the bleeders) including the abs "module". i suspect that dirt/rust ocassionally gets stuck in a valve somewhere. can anyone suggest a remedy?????
