TheBugster
I am planning to run my 2007 ZO6 in a track event at Pocono Raceway on Memorial Day. Tech Inspection requires at least DOT 4 brake fluid. The ZO6 comes with and specifies DOT 3 fluid. Is there any problem with flushing and refilling the system with a DOT 4 fluid, such as Castrol LMA? Also, many fluids now available, including Castrol, are synthetic. Is that a problem? Technicians at Criswell Chevrolet have told me that these changes are fine and that many owners make the switch for track events. On the other hand a friend of mine who has a Ford GT told me that it's not recommended for that car because it could damage the brake seals under heavy braking. Anyway I would appreciate any advice that would help clarify this. Also, could it void the warranty?
Thank you. The Bugster
