B
BORDERBUM
Ladies and Gentlemen,
Is it normal when you depress the brake pedal for a valve to open up and make a hissing noise under the dash?
I got under the dash and there is a valve of somesort , sorry for my lack of the correct parts names, when the brake pedal is depressed when engine is running there is a valve that lets air out, loud. When the brake is not depressed the valve is depressed by the brake pedal, when the brake is depressed the valve pops out and releases air.
I have yet to get my headlights to function correctly and it seems like not enough air is getting to them, could this be a reason? maybe a blockage somewhere and air has to escape here? I don't have a clue, my knowledge of vettes comes form what i have to fix on my 77 since my other two are far from being on the road. when i manually raise the lights the passenger side goes down when i shut the lights off, other than that nada.
git r done borderbum
