Brake Pressure Distribution
amledford
GR Michigan
2001 Champaine Coupe
Does anyone know what the brake pressure/force distribution is between the front and rear tires? I'm not sure what book(s) would give that info, and I know that there is some ratio between the front and back brakes to aid the ABS.
Mike
HI there,
On your car, 01, there is electronic brake distribution, which is constantly changing. This is based on pitch of the body, yaw rate, and a few other parameters.
There is not a proportioning valve, like on the older c5.
Alltehbest, c4c5:hb
