MR. T.
I just got my 77 out of storage and have to do the work for the safety. I have just starrted working on it and already problems. I can't remove the front rotors that I need to replace! I drilled out the large flat head of the rivet and have tried everything I can think of to get the rotor off of the hub, nothing works, have soaked with penetrating oil and have tapped with a hammer, but they are seized solid. Any Advice?
I have also discovered a leak of transmission fluid, may be the pan gasket, but I will investigate further, as well the parking brakes is in bad shape, rear cable is seized and the left rear is also seized (much rust.) I am sure I will be back looking for more assistance, thank you to all how reply.
