A
Alfonso Gomez
On february I posted my problem with the brakes. In a nutshell, when the engine hit 205-210 degrees during a nasty traffic jam, the brake pedal went down to the floor. After sitting for an hour, the brakes were back to normal. The general consensus was either heat soak or contaminated brake fluid. It did happen once more about a month after thet first time (in March) and after cooling off for half an hour the brakes went back to normal.
I started avoiding using the car too much until in April I took it to a GM dealer and had the brake system purged and the brake fluid changed (Wynn's Friction Proofing System). They used a pump to take out all the old fluid and put in new fluid.
This weekend I took my wife for a ride (90 degree weather), got in a traffic jam, the coolant temperature went up to 215 degrees and the brakes started to fail once more. I checked the fluid and it was clean and clear, not muddy or dirty. It was very hot and the master cylinder was VERY HOT. My idea is the the master cylinder gets too hot, expands and the rubber "piston" inside is not sealing properly.
Is this possible?
Is this possible?
