S
Steve92LT1
Well I have a 92 and I have been having a problem with my driver side headlight not going up.. like it was sticking. If I "helped" it start, it would work. I had another post about troubleshooting and all.. Well.... it's not electrical, it's the motor.
The actual motor part looked good inside, the brushes, commutator and all.. I cleaned that part up.
It's hard to explain, but I think it's binding in the gear part, also because once the motor closes, it's kinda tight to loosen the manual knob. It's like it screws tight.
I finally disassembled the gear part of the motor and the bushings have been replaced before, but the big plastic gear is kinda "mangled" looking. It had some flattened teeth and doesnt look so great.
I've looked online and cant find any info on symptoms of a bad gear, all I can find is the bronze replacement gear with no info basically.
Is this my problem?
I don't want to spend $60 on a gear and come to find out that it's not the problem
Steve
Is this my problem?
Steve
