6
69vettester
He wasnt totally buck wild there but D..mn I cant figgure out how someone could have done some of this, and all of it was just simple little maintenance things?
heres the list to date..
1. excellent Morosso plug wires..Not fitted (Crimped) correctly, some were actually damaged,
2. Blown header gasket on passenger side, wrong bolts, only one bolt had a flat on it, the rest werent even clamping :confused
3. 1 Gooseneck mount bolt had stripped the threads out of the aluminum manifold. the bolt was gobbed with a permanent loctite of somesort and reinserted :eek
This may be the entire list (Im hoping) and for all I know, may have all been done in one mad bubba afternoon episode,
The entire rest of the car has had obvious and excellent proffesional care in its restoration.
anyhoo Just thought I'd share these puzzling things with all you on the forum..
Cheers and beers..
Tom
Cheers and beers..
Tom
. In my attempt to save a few bucks, i had just cost myself several hundred. As an interim fix (this is where Bubba comes in) I took a c-clamp I used for furniture building and rigged it across the lip of the valve cover and the plenum bolt to keep the valve cover tight so I could drive the car until I could afford to fix it. I ended up not driving it til it was fixed but that c-clamp looked really strange under the hood.
