T
TonyTM
Does anyone know if the build sheet is inside the 86 vette? I'm trying to figure out if I have cast iron or amluminum heads and you can't see the stamping on the motor with everything in the way.
Don't the aluminum heads have the center bolt pattern heads for the valve covers? I know mine does. I've never really looked at many cars without AL heads.
That's true![]()
Either on top of the gas tank or inside the front crossmember with the front spring is where I'd look for the sticker.
As for aluminum heads, all 86 Convertibles had them and most late production Coupes had them. With the coupes, the exact break point between iron and aluminum heads is unknown, but Antonick's Black Book has stated for a number of years that "...it is believed that the last 8594 coupes had them."
As for whether or not you have them on the car in question, if they're iron they'll be painted black. If they're aluminum they'll be unpainted and silver.
