M
MusclesWit350
Does anyone know where I can find the build sheet on a 80 Vette and how hard it would be to get to? Also is there any place to buy a build sheet or window sticker?
Thanks!
Thanks!
MusclesWit350 said:Is a dealer invoice the same as a window sticker?
82ColEd said:And the built sheet is most often found on top of the gas tank....
6880 Mike said:IF it's still there. Not worth dropping the tank only to find nothing. Copies of build sheets have been found behind either kick panel, tucked in the springs under a seat, under the carpet in the rear storage area, in the wiring behind the speedo/tach, in the wiring behind the center cluster, and (at least once) folded and tucked in the rear spring mount. Any or all of these copies may have been found and removed by previous owners. On the chance any of them still exist, they are approaching being thirty years old. You can expect them to be extremely delicate and possibly illegible.
Without actual documentation from a previous owner, your best hope is a copy of the dealer invoice from Allied Vaughn.
MusclesWit350 said:How can I reach Allied Vaughn?
As 6880 Mike said, the dealer invoice and window sticker were prepared at the same time with the information from the build sheet. The sticker went on the car; the invoice went to the dealer when the car shipped.MusclesWit350 said:Thanks! I will be ordering one right away! Also has anyone ever ordered a window sticker from this site- http://www.window-sticker.com/ if so does it look real? They say they can make one from an invoice so I was thinking about ordering this too...
Brian:I received a copy of my original invoice from Peggy Veniza GM Media Archive 200 Renaissance Center, Floor 35, C-4 Detroit, MI 48265. I mailed a letter to these fine people with my VIN number name and address and received a copy in about two weeks. The cost to receive this copy was nothing. About the window sticker, the same window sticker was used from 1976 through 1980 and yes the window sticker pictured on the windowstickers.com web site is correct looking. There are re-pops of this window sticker sold on e-bay but they are not correct if you look at them close. The hard sticker to find is the warranty sticker. Both the window sticker and the warranty sticker card were affixed from the assembly plant on the right window. Once the car was received at the dealership the warranty card sticker was removed from the window and one of the 8 VIN number stickers was then removed and placed on the warranty card booklet and was in the new car packet along with all other original documents.
Brian
Thanks for the update. Yes it has been a while, the envelope that the copy of the invoice is dated March 2005.Brian:
It's probably been a while since you received that information from anyone in the Renaissance Center. That whole group no longer exists inside GM, and you need to contact Allied Vaughn, as indicated in an earlier thread. I think you might also be able to get the information from the National Corvette Museum.
...I think you might also be able to get the information from the National Corvette Museum.
