6
69_Dream
I need help guys
I've got an original 69 427/390 that has started to burn oil and it's coming out the side pipes, ouch! :cry
Oil seems to be leaking from the rear of the intake manifold. Is that even possible? Somewhere near the distributor? Again, I'm a little stressed right now so maybe I'm not being clear, or else I'm explaining it wrong.
It seems fine if I just start it up in the driveway. The problem develops after driving a few miles.
2 items that have changed just a few miles prior to this starting:
1. Found a plug that hadn't been connected - and here I was thinking I had a timing problem :L
2. Added half a bottle of lead additive to the gas
Can anyone point me in the right direction? Keep in mind I am NOT mechanically minded, nor mecanically capable. I can hold my own pulling apart a door or fixing a convertible top, or else a radio or redoing a carpet... just not really good when it comes to engines. With all that in mind, I'm more than a little worried right now, seeing as this is its original block and all.
Should I be driving it at all or should I have a tow truck come get pick it up and bring DIRECTLY to an engine rebuild shop? Can anyone out there help? Anything to point me in the right direction would be great. Thanks.
Sly
Sly
