C-5 Question
  • Thread starter Thread starter James Lopez
J
James Lopez
C-4/C-5 Specialist, do you or anyone know if the Seat Adjuster w/Memory #88953529 fits all the C-5's including the 2004's or 2003's. Any information would be appreciated. Thank You
HI there,
All the seat adjuster mounting points are the same, and will fit all c5, 97-present date.
The only difference in the part numbers is the memory package. You can tell those with memory package, as there are 2 pin connections on each motor, which require plugs from the unit control module.
Allthebest, c4c5:hb
