GetVette
Recently, my 2000 6-speed drop top passenger window began acting up. When fully DOWN the window did not roll back up and only gave a subtile control module "plunk" when the window switch was pressed to either up or down.
Two pluks for up, one for down and a small voltage drop in the down position. I removed the door panel and sound abatment covers and with the control module and door switch assembly hanging freely, whacked the door shell 3 times with a rubber hammer where the window motor is mounted. This fixed things for about a week when the problem occurred again. I know the motor works but don't know if the control module is defective or if there is a switch inside of the cable spooler mounted on the motor assembly that cuts power in the fully down position. I would GUESS that the window travels down to the bottom, the power remains at the motor which causes it to get quite warm and then a lockout occurs. Anyone else have this problem and what can be done to fix it without seeing the dealer? Is the control module the sole power control for the motor under these circumstances.
Thanks, BG
2000 6-Speed Drop Top, LS1, Silver, 11,000 miles
1979 Coo-pay L-48, Green, grocery getter. 85,000 miles
1981 Coo-Pay L-48 Silver, almost show quality 40,000 miles
2002 EZ-Go Golf Car, Green, Electric Hybrid Vehicle, 4 miles per volt
Thanks, BG
