Hib Halverson said:
I think the way to approach this is to use the C5s PCM to control the LS2. That task would be far less complex than trying to get the '05 PCM to work with the C5 electrical system.
Hi there,
If I may comment on integrations of the c5 vs c6.
The concern, IMO, based on what I am aware of the c6 design, is wiring and PCM design itself, NOT just communications data lines.
The Throttle actuation control is built inside the PCM on c6, this was not the case in c5. There was a separate control computer for the throttle system.
While the communications data lines are definately entirely different using GMLAN 2 wire communication for the major powertrain and traction control systems, the subsystems are very similar, using Class 2 single wire.
This, plus integration of the TAC module inside the PCM, creates the issue here.
I feel that Hib is on the right track, installing a 6.0 LS2 in the c5.
I have only one concern with the mechanical aspect, the cam phasing portion of the engine, which carries a different oiling system than on previous engines.
Other than that, I feel Hibs ideas are the best, and most cost effective.
Time will tell, because there is already a study being done on this.
Allthebest, c4c5 :eek
